주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
After screen replacement, screen gets hot
Hello,
after we replaced the screen of a i6+, the customer came back with the issue that it gets very hot under the frontflex.
The heat is actually coming from the flexcabel of the lcd screen.
We testet it with 3 other screens from different suppliers, changed different frontflexcables, cleaned everything completetly with isop and always the same problem.
Also if we start the phone with only the lcd connected it gets hot at this special point.
But connector self looks absolutly fine.
Maybe someone had already this kind of problem and knows something?
Any help would be very much appreciated.
Thanks and kind regards
Alex
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Has it had any water damage at all? if its not the LCD itself, the motherboard connector pins may be bad or the motherboard itself. Could also be draining all the power out of the battery if that was not replaced causing it to heat up everything..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks for the reply,
no waterdamage and the connectorpins looks good.
The battery is also not the problem.
Any other solutions?
Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I came across the same issue guys if you NOTICE THERES A 3M BLACK STRIP ON THE VERY FINE LEFT TOP OF MOTHERBOARD FOR IT NOT TO DO DIRECT CONTACT WITH LCD ASSEMBLY
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 3,159
