주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
293 질문 전체 보기
Can I replace the HDD part of a 2 TB fusion drive with a SATA SSD
Can I replace the HDD part of a 2 TB fusion drive with a SATA SSD (Samsung EVO) and leave the 128 GB Apple PCIe NVMe SSD in place? Can I use both as two separate SSD drives?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
What are you trying to achieve with this move? Have you studied the concept of a fusion drive setup?
fusion is based on optimizing io-performance through storage-tiering with fast and slow drives
wanna split the fusion drive and have only SSD storage in mac
buying a SSD only mac is much more expensive and is lacking SATA cable wich is hard(er) to add, looking to only replace the hdd if possible
댓글 달기
답변 1개
선택된 답변
mmm...
If you haven't bought your system yet I would get the bigger straight SSD model (sans the HD). Getting the needed SATA cable is not hard. But getting the custom Apple SSD is quite difficult! Get the largest you can afford. Then for now just get an external Thunderbolt or USB HDD drive.
In a year when the warranty has expired think about upgrading the system with a second internal drive. By that time the SATA SSD options will be cheaper.
Opening up the newer 'Thin Series' is a bear and if you're not careful its quite easy to damage the display which would be a very expensive Opps! Besides Apple won't honor any warranty repairs (first year) if you've opened the system.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I saw a OWC video, connecting a SATA cable to the MB requires a complete disassemble of almost all components, that's why I thought its easier (and cheaper) to by a 2TB fusion drive model for now and when warranty has expired, replace the fusion HDD with a SSD if that's possible. Don't need an external drive then (the largest internal SSD I can afford isn't large enough for all my data)
Well... Yes, it's a bit more to pull the logic board up enough to plug the cable. But is it worth having a skimpy SSD (128 GB) vs going with a 512GB or if you can swing it a 1TB high speed NVMe x4 vs the much slower SATA III (6.0 Gb/s). It's not that hard once you get past getting the display off without killing it.
And don't forget you'll have a 2 TB HDD for the junk pile which you spent $250 for.
Again, wait on adding the second drive till the warranty has expired.
댓글 달기
귀하의 답변을 추가하세요
Roger 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 460
