주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5G does not start
hi friends
how are you ????
I have a 5G iphone that does not start when I plug on power supply it goes up to 0.04A but does not want to start
When I plug the multimeter it shows me 0.87V
From you where the problem comes from
View pictures
thinks my friends
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi Mike. What are you measuring that gives you 0.87V? Is it PP_BATT_VCC? or PP_VCC_MAIN?
With a dead phone, you really have to start at the beginning. Check PP_BATT_VCC & PP_VCC_MAIN to see if they are shorted while the phone is unpowered. I wouldn't put any power on it until I am certain the main voltage rails are not shorted. If they are shorted, then that issue has to be resolved first.
If they are not shorted, then something downstream is causing the problem. I would then look at the output voltages of the PMU/PMIC (U7) to see if any of those are shorted. If there are shorts, then focus on those. Once all the shorts are gone, then power the phone to see what it does.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
My friend
Please how to check the vcc main and pcc bat ??
I can not
When I plug in the power supply it does not ring
And when I apply the cold spray I do not see anything short circuit
LOLLLLLLLLLL
It is turned on by itself
thinks minho thinks friend
댓글 달기
귀하의 답변을 추가하세요
Mike Plouvin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 117
