주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The next-generation 2007 Santa Fe debuted at the 2006 North American International Auto Show in Detroit.
My at transmission stuck on 4th gear and not change
i have a hyundai sant fe 2010 i have change my engine 24 after changing it in workshop my at transmission start to stuck on 4th gear not chancing at all i tried a lot of solutions but no thing happen
solution have been tried:
1-tithing the battery cabels
2-changing the oil of the transmission
3- software to the transmission of the car by obd2 scan and reader code device
note(when i get my car to a obd2 scanner it shows that one of the selonide are not working and when repeat the scan it gives onther selonide not working and the first which is shows in the first scanning work good in this scan and move on in every scan one work the other not after change in the other scan
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hello,
I had same issue with santa fe 2010 3.5 and whole gear box changed and it costs too much.If you have this problem that is when you should consider why always me
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
abdaladem alwan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 40
전체 시간: 3,059
