poor wifi and bluetooth signal after screen replacement
hello,
after a screen replacement with a refurbished one, now i have poor wifi and bluetooth signal on my lg g5. i suspect an antenna issue. someone know what could be the matter?
좋은 질문 입니까?
hello,
좋은 질문 입니까?
yup sounds like the antenna. order a replacement and swap it over.. if this doesn't fix it, will most likely be a logic board issue. 90% of all cases on the device is the antenna.
furthermore make sure you reseat the antenna connection.
해당 답변은 도움이 되었습니까?
hello, thank you for your kind reply. Do you know where can i find the wifi/BT antenna in the logic board?
8 minutes ago by Gabriele Filoni
I had exactly the same issue. Check the antenna cable, it is under the motherboard, one of the connectors was disconnected, in my case and that solved the problem. Probably, when I was replacing the screen I accidentally disconnected the cable.
해당 답변은 도움이 되었습니까?
Thank you very much it works!
24 시간 전: 1
7일 전: 18
30일 전: 22
전체 시간: 1,092
댓글 2개
Gabriele Filoni 의
Hello
I have the same problem, did you find a solution?
Camera5 Amazon 의
