주요 콘텐츠로 건너뛰기
The Samsung UN55KS9000F 55-inch 4K SUHD TV is a flat panel 2160P TV. Released from Samsung in 2016. Model number: UN55KS9000FXZA.
27 질문 전체 보기
My Tv has a big crack in it
My Tv has a big crack in it and was wondering if and how I could replace the tv screen?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
@jordan_bolt I have a question. is TV screen broken or it's panel?
my TV panel broken too but it broke on its own.
댓글 달기
답변 2개
Really easy, its only 4 screen on rear cab and 2 screews on PSU.
Just be carefull then opening rear cabinet.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Were can you buy them from
댓글 달기
@jordan_bolt yes you could replace the screen, if it were available. LCD screens that size are not easily found and will cost you more than a new TV. You will have to take the back of your TV and find the manufacturers label on the panel. Then use that number to do a search. Only other option would be to find the same model TV as yours but has other parts broken. Then harvest the LCD from that TV.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jordan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 3,009
