Answering Machine reads 88. Is this error message?
Answering machine will not replay the messages. The readout is flashing the numeral 88. We used the handset to remove all but one message. It seems to have the ability to record a message, but to hear it replayed you have to use a handset. Is there a solution to enable the answering machine base to work properly?
좋은 질문 입니까?
댓글 2개
Most likely if it is showing 88 it is the front panel that is broken. If the buttons and screen are being strange, the connection might be broken. Don't have this answering machine, nor have I seen this problem before. Hope this helps!
Gabriel 의
Thank you, Gabriel. The main base is really acting strange. It will not replay a message at all, or it stops after starting to replay. That 88 number appears and it just stops it's function. Guess it's time for a new system. The two phones and the remote base seem to be working properly.
Lynn 의
