주요 콘텐츠로 건너뛰기
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
199 질문 전체 보기
Reading PS1 disks fine but refuses to play PS2 games
Alright I have been working on a PS2 that I managed to rescue from being used for parts on Ebay, it had been stripped down and sold for not working but I found out that the issue was a broken fan connector which took minutes to fix. I have since reassembled it and its been working fine with older titles like PS1 games, I do have to use a AV cable for them to load since using a composite video cable just gives a disk read error, I would test it with a SCART cable but I don't have one around.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi!
Could be the lens in the optical drive going bad.
Try wiping it with some alcohol and Q-tips, if it does not work you should replace the laser assembly.
PlayStation 2 이미지
안내서
PlayStation 2 Optical Disc Drive Lens Cleaning
난이도:
쉬움
15 - 40 minutes
PlayStation 2 Optical Disc Drive Laser Assembly 이미지
안내서
PlayStation 2 Optical Disc Drive Laser Assembly Replacement
난이도:
운영
20 minutes
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Do not use alcohol on dvd/cd laser lenses
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
1337KILLERZ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 662
