주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 2 Optical Disc Drive Lens Cleaning
필요한 것
  1. PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: 1 단계, 이미지 3개 중 1개 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: 1 단계, 이미지 3개 중 2개 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: 1 단계, 이미지 3개 중 3개
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    댓글 쓰기
  2. PlayStation 2 Optical Disc Drive Lens Cleaning: 2 단계, 이미지 1개 중 1개
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
    댓글 쓰기
  3. PlayStation 2 Optical Disc Drive Lens Cleaning: 3 단계, 이미지 1개 중 1개
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
    댓글 쓰기
  4. PlayStation 2 Optical Disc Drive Lens Cleaning: 4 단계, 이미지 2개 중 1개 PlayStation 2 Optical Disc Drive Lens Cleaning: 4 단계, 이미지 2개 중 2개
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    댓글 쓰기
  5. PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: 5 단계, 이미지 2개 중 1개 PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: 5 단계, 이미지 2개 중 2개
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
    댓글 쓰기
  6. PlayStation 2 Optical Disc Drive Lens Cleaning: 6 단계, 이미지 1개 중 1개
    • Carefully wipe the lens in a circular motion with a rubbing alcohol damped Q-Tip.
    • Do not over-dampen the Q-Tip with rubbing alcohol.
    • Allow a few minutes for the rubbing alcohol to evaporate.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 73명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
emessers
회원 가입일: 10/28/09
2,948 평판
안내서 1개를 작성함
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 회원
CPSU-MANESS-F09S19G1
4 회원들
안내서 35개를 작성함
10가이드 댓글
I've tried the steps mentioned above to no avail. The problem persist. Anything else i can do besides purchasing another console? Sentimental value.Thank you.
Albie - 답글 공유
What I'm gonna try and do is take a laser from a PC DVD burner tray and see if I reads things. It's a long shot but you can't break what's already broken ehh. I'll let you know what happens. And if it works I will write the proper tutorial for it:)
Yuri weinberg - 답글 공유
HOw to use a lens cleaner dvd in Ps2
sajidsahito110 - 답글 공유
please answer my problem
Hi
I have problem with my ps2 when I put the cd in the screen says that it's reading the cd but after a few minutes it stops and says no data.
What should I do ? how do I fix it ? And any clues on what to do?
Arif Ali - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 135
지난 30일: 626
전체 시간: 128,587
