주요 콘텐츠로 건너뛰기
The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Can I only change digitizer and not the LCD?
Can I only change digitizer and not the LCD? My screen top layer is broken, the digitizer and lcd are fine, I don't think there's any way to change the top glass without changing digitizer and touch screen.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You can cgange just the glass but this is not easy. In fact if you have never done this repaor before you are probably better off replacing the lcd. You can try to replace the glass but you will probably end up causing damage to the lcd therefore you you might have to get a new lcd after the glass replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you for this reply! I am in the same boat -glass is scratched but the screen is fine. Wondering if I should replace just the glass (digitizer) or do a combo with the screen. What makes the digitizer only replacement so difficult? I've only done screen replacements before, not digitizers.
Thanks @harisahmed123 . I'd like to try this (i.e. replace digitizer only and not the whole assembly with LCD panel). LCP panel is fine (I can still use the phone) but screen cracked.
All videos I see on the HTC 10 are to replace the whole LCD assembly. You know of any video showing the digitizer replacement?
댓글 달기
답변을 추가하세요
Mahdi Mohammadi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 787
