주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ZenFone 2 (ZE551ML)은 2015년 3월에 출시된 ASUS의 Android 스마트폰입니다.
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 7개
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
Different battery perhaps?
Do I have to try with a different battery? Can it be a motherboard's problem ?
Yeah, it could be either the mother board or the battery.
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
댓글 2개 더보기
댓글 달기
답변 1개
선택된 해법
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Asus ZenFone 2 배터리 이미지
안내서
Asus ZenFone 2 배터리 교체
난이도:
어려움
20 minutes
Asus ZenFone 2 마더보드 이미지
안내서
Asus ZenFone 2 마더보드 교체
난이도:
조정
15 minutes
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
댓글 달기
답변을 추가하세요
Vincenzo Liguori 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 675
