주요 콘텐츠로 건너뛰기
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
99 질문 전체 보기
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 7개
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
Different battery perhaps?
Do I have to try with a different battery? Can it be a motherboard's problem ?
Yeah, it could be either the mother board or the battery.
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
댓글 2개 더보기
댓글 달기
답변 1개
선택된 답변
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Asus ZenFone 2 Battery 이미지
안내서
Asus ZenFone 2 Battery Replacement
난이도:
어려움
20 minutes
Asus ZenFone 2 Motherboard 이미지
안내서
Asus ZenFone 2 Motherboard Replacement
난이도:
운영
15 minutes
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
댓글 달기
귀하의 답변을 추가하세요
Vincenzo Liguori 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 377
