주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ZenFone 2 Battery Replacement
필요한 것
  1. Asus ZenFone 2 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 2개 중 1개 Asus ZenFone 2 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 2개 중 2개
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
    댓글 쓰기
  2. Asus ZenFone 2 Battery Replacement, Remove the Inner Cover Screws: 2 단계, 이미지 1개 중 1개
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
    댓글 쓰기
  3. Asus ZenFone 2 Battery Replacement, Remove the Inner Cover: 3 단계, 이미지 2개 중 1개 Asus ZenFone 2 Battery Replacement, Remove the Inner Cover: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
    댓글 쓰기
  4. Asus ZenFone 2 Battery Replacement, Remove the Speaker: 4 단계, 이미지 1개 중 1개
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
    댓글 쓰기
  5. Asus ZenFone 2 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Use a plastic prying tool to carefully detach the bottom part of the antenna.
    • The antenna can be easily bent out of shape. Be sure to lift from underneath the cable as shown.
    댓글 쓰기
  6. Asus ZenFone 2 Battery Replacement: 6 단계, 이미지 2개 중 1개 Asus ZenFone 2 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, unlock the ribbon cable indicated in the picture by prying up the yellow tab.
    댓글 쓰기
  7. Asus ZenFone 2 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, remove the vibration motor from its housing.
    댓글 쓰기
  8. Asus ZenFone 2 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Gently remove the board from the phone using your hand.
    댓글 쓰기
  9. Asus ZenFone 2 Battery Replacement: 9 단계, 이미지 2개 중 1개 Asus ZenFone 2 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, gently pry the ribbon cables up as indicated in the pictures.
    댓글 쓰기
  10. Asus ZenFone 2 Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully remove the battery pack from the phone using your hand.
    • There are fragile tabs on the left and right side of the battery, be careful not to break them off.
    댓글 쓰기
  11. Asus ZenFone 2 Battery Replacement: 11 단계, 이미지 3개 중 1개 Asus ZenFone 2 Battery Replacement: 11 단계, 이미지 3개 중 2개 Asus ZenFone 2 Battery Replacement: 11 단계, 이미지 3개 중 3개
    • Carefully insert the metal spudger between the battery and its metal housing and then slowly pry the two apart.
    • Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone.
    댓글 쓰기
결론
Put in a new battery and then reassemble your device by following these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 83명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Eduardo Nodarse
회원 가입일: 02/10/16
4,812 평판
안내서 5개를 작성함
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G5
4 회원들
안내서 31개를 작성함
31가이드 댓글
Great job with excellent photographs and detailed explanations! Unfortunately this phone is a real goat rodeo when it comes to just replacing a battery. My phone froze and nothing seemed to help unlock it. Fortunately, I went back to an Android site and found the answer and was able to reboot it (holding the on/off button for 10-15 seconds) without trying to remove the battery. Thanks to you I've learned two valuable lessons.
Michael Pobjecky - 답글 공유
How can i buy the battery for my Zenfone 2 ze550ml .I want 100% original li-po battery.
Skanda - 답글 공유
my zenfone 2 charging very long time and berry laevel vry sort time discharge
shailendra - 답글 공유
i replaced my Zenfone 2 ze551ml's battery carefully.
But when i put everything back ,it can not turn on .
the vibration motor is the only thing working
every few minutes the vibration will vibrate two times itself.
Can anyone tell me how to solve this problem,thanks
angus - 답글 공유
Hi there I'm having the same problem with my phone, did you get any responses on how to fix the problem
mcummings197023 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 62
전체 시간: 89,598
