주요 콘텐츠로 건너뛰기
The camera has a 2.7” LCD screen, a 12 megapixel Four Thirds sized sensor, and a built - in flash. Dimmensions are 115 x 72 x 42mm.
17 질문 전체 보기
The small internal date time battery data what type is it, where?
The internal data battery does not hold the date and time when replacing the main battery on my Olympus E-PL1. What type of battery is it? and where is it located?
I hope you can help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
that sounds write changing a small capacitor inside without a circuit diagram and component list could be dodgy! I am capable with a soldering iron. Olympus service won't tell and want to charge more than the camera is worth. If anybody knows the value of the capacitor ( farads) it will quite small. I should be able to get the component and fix it Thanks rokin154@crowbot.
They call these components "super caps". It's possible you could locate it on the board. Likely the farad rating would be kind of high with the voltage being low (5V, 12V). Best of luck.
댓글 달기
답변 1개
선택된 해법
It's likely that the camera uses a capacitor to keep the clock and memory up while changing the main battery. If the cap fails (as they sometime do) then you'll see this problem. If that's the case the only solution is having it repaired.
I found this during a search. https://www.dpreview.com/forums/thread/3...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Robbie Cwik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 32
전체 시간: 1,903
