주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
iPhone 6 only flash not working
Hi all!
After replacing my iphone 6 (no plus) screen, the flash stopped working. It does not work either in torch mode or in photo / video mode.
The rear camera works well.
When the torch button is pressed, the flash flashes for a few moments, as in this video (https://www.youtube.com/watch?v=KqxVgYUj...).
I recently replaced the flash but still have the same problem.
Solutions?
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
your Video ( This video is unavailable.)
I modified the link.
power button flex cable is what contains the flash module
댓글 달기
답변 3개
선택된 해법
If you have already tried Scott's suggestion, then your problem is on the logic board. It looks like the flash circuit enables the flash but probably limits out once the full current load is required. This could be the Strobe Driver IC (U1602) or the Strobe NTC filter Fl0817.
Regardless, this will need to be looked at by a reputable micro-solderer.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thanks Minho for your interest. I have not used the flash for a year now and I almost gave up. I'm not a micro-solderer, however I can do some other proof that does not involve big risks?
I have the same problem how I can resolve? (iphone 6)
댓글 달기
try a new power flex cable after checking all of your settings. This cable contains the flash module
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have already tried to replace it, but I still have the same problem.
댓글 달기
Hi. I have the same problem after I dropped it about 3m. I also replaced the cable. LED does still not work. I have the tools to do micro soldering. What do I need to replace?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Francesco 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 13,514
