주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
295 질문 전체 보기
RAM Upgrade to more than 16Gb?
My new top of the line (maximum options MBPro) struggles more to cope with large files and edits in Lightroom than my old one.
Can the RAM be further increased to more than 16Gig?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 1개
Sadly, you're not the first to need more than 16 GB of RAM.
You might want to look at freeing up as much space on your internal SSD storage as you can as I'm sure you are running lean on free space. That way your system will be able to leverage it for virtual RAM. For storage of your work get a Thunderbolt external RAID drive (SSD if you can swing it).
댓글 달기
답변 2개
선택된 해법
If you didn't buy the upgrade from Apple, no.
If Apple didn't make that option, no.
This machine has ZERO upgradeability. All upgrades must be purchased upfront and requires Apple providing the option in the first place.
해당 답변은 도움이 되었습니까?
점수 4
2 댓글:
There was no option of more RAM available
The only option was to get the larger SSD storage which would have helped a bit.
댓글 달기
가장 유용한 답변
Apple, in its infinite wisdom, is telling you that you don't need more RAM.
There is nothing wrong with your Macintosh.
Do not attempt to adjust the picture.
We are contolling the transmission .
If we wish to make it louder we will bring up the volume.
Is we wish to make it softer, we will tune it to a whisper.
We will control the horizontal.
We will control the vertical.
We can roll the image. etc., etc
We will control all you see and hear
https://www.youtube.com/watch?v=FCcdr4O-...
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
귀하의 답변을 추가하세요
Gerrit Wyma 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 29
전체 시간: 13,747
