주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi 전용 버전의 Apple iPad Air(모델 번호 A1474)입니다. 스페이스 그레이 또는 실버 색상으로 제공되며 맞춤형 A7 프로세서가 탑재되어 있고 16, 32, 64 및 128GB 용량으로 제공됩니다.
Digitizer Replacement screen dead again
I recently replaced a dead digitizer on my Ipad Air.
When I completed the repair everthing was working fine. I used the Ipad for about two days, then I put it in a case and turned it off and put it in my woodshop (Its a backup Ipad and I don't use it very much). That was about 3 weeks ago.
When I turned it on today the digitizer was dead again. What is the most likely source of the problem? I don't have another digitizer to test if its faulty, but is that the most likely problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
When you say the digitizer is dead, do you mean you can see the screen like normal but it won't respond to touch?
If that's the case, then I would open it up again and inspect the connections and everything else you touched during the initial repair. If everything looks fine, then only another digitizer would allow you to properly troubleshoot this.
If you can't see the screen, then your problem is elsewhere.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
James 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 84
