How do I glue the white screen gasket on my MacBook A1342?
The white screen gasket (trim) on my MacBook A1342 is peeling off. How do I insert it back? It keeps peeling back off even when I insert it back. It only happens at one specific spot. I don't want to replace the trim. I just want to glue it back in. What kind of glue-adhesive may I use?
좋은 질문 입니까?
댓글 2개
I would guess a small amount of superglue would work just fine. I'd get a second opinion , though - I never like to pose as an expert - I don't know how the glue would react to rubber. Just use it sparingly and wisely.
Jack 의
@secondlife Thank you for your comment. If you add it as an answer I will select it as a solution. I´ll try to look up the special glue you mentioned but I think I will just cut one or two milimiters off the trim and then stick it back in. The reason it´s pulling out is that it got stretched somehow so now I can´t push it back in. Disassembling the screen is out of question as it´s too much trouble, I don´t have the tools and could do more harm than good. Thank you
Dario Meze 의
