주요 콘텐츠로 건너뛰기
다양한 TV 브랜드 및 스타일 안내서 및 지원.
9051 질문 전체 보기
My SONY 40" LED TV has no picture but has sound?
Hello. Please help me with this.
My SONY LED TV has no picture but it has sound. There's no SONY logo during startup but there's an obvious very dim light. I have tried powercycle but no go. I've tried using flashlight to check for any picture on the screen but seems like I cannot see any. I did not open the back yet to check for the ribbons and pins.
What could possibly be the problem and the fix?
Thanks so much.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 10개
A pleasant day.
Here are pictures of the boards when I opened the back panel.
SONY LED TV
Model: KLV - 40R352C
I've tried reseating all the possible cables that I can see but still the issue persist.
Would you recommend using another power adapter with higher AMP rating?
Need more help.
@julzryu a higher amp power adapter will not make a difference.
Yeah the led indicator flashes red. Please let me know how to resolve the problem
This is a bad product.
I have the same problem.
I have the same problem too, no solution yet, i have the same model only worked for a year and a half.
댓글 5개 더보기
댓글 달기
답변 6개
선택된 답변
@julzryu the very first thing you need to let us know is if the LED indicator is flashing red. If so, count how many times it flashes and let us know. If the LED indicator flashes red, reset the TV by disconnecting the AC power cord from the TV for two minutes, then turn on the TV.
Then start with the basics by checking the items as follows:
No picture (screen is dark) and no sound
 Check the antenna (aerial)/cable connection.
 Connect the TV to the AC power outlet (mains socket), and press / on the TV or remote control.
No picture or no menu information from equipment connected to the video input jack appears on the screen
 Press to display the connected equipment list, then select the desired input.
 Check the connection between
If that does nt work you need to check your power board and/or your mainboard. You also want to check the T-con board. First thing there is to check the fuse. Post some images of all of your boards with your question. For that use this guide 기존 질문에 이미지 추가하기 so we can see what you see.
Update (09/11/2017)
If you do already have it apart, check a few things according to the SM
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
First thing I would do and check is the connection from the board to the LCD. Not exactly sure where that would be on this model but it should be fairly simple to trace. Try reseating the cable as well. If it still does not work you probably have a issue with 1 of three things : LCD power / Image signal and or processing from the logic board / or a bad LCD panel.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Hi,
I have KDL-50800c. I was facing problem of vertical lines all over the screen. one youtube video showed same problem for same model and solution was replace T-con. Now i have replace with new T-con but after that i can see only LED white light and bit flash on my screen.Same problem as described in the forum.
I thought problem is with new t-con. so i tried with old T-con but it is also start giving me same problem. I am not sure, placing new T-con cause some other problem in TV.
I will appreciate for the answer
댓글 달기
More than likely to be faulty LEDs. Trouble is they are deep inside the unit and need to know where what is.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Our Sony Bravia started flickering in the top third of the screen, then went black within minutes. Sound stayed on.
After unplugging power cords, checking connections, cycling unit, Still no change. At start up, Sony logo comes up then quickly goes black.
Having researched the web, suggestion was to use a flashlight on the screen at an angle to see if faint images could be seen. Found images were present. So further search revealed three faulty LED ribbons. Carefully removing chassis from screen, reveals the 3 led ribbons. I removed them and bench tested to find 5 LEds were faulty, at least one on each strip. Waiting for new replacements from Hong Kong to arrive. Hope this solves the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes the LED backlight is faulty. Great care must be taken not to damage screen etc. Vince.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi my sony kd - 65x9300d is not showing the video it opens all the aps showing the display as soon as I play any movie or series the screen goes blank on the tool bar come and the setting
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have rest it many times
댓글 달기
귀하의 답변을 추가하세요
Jules Malao 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 46
전체 시간: 71,941
