주요 콘텐츠로 건너뛰기
The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
81 질문 전체 보기
I can not charge my phone
My phone ran out of charge, it was flat for 4 days when I tried to charge it again it would not charge. I do not know if the problem is the battery or the hand set but the hand set dose not even show a charging light.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
@philthy it is possible that your battery is discharged beyond it's threshold and does not longer take a charge. I'd start off by checking the charger itself. then the cable and finally the charging port to make sure there is not line or debris which prevents your phone from charging. If all that looks good and shows the proper voltages, replace the battery and reevaluate.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
As it turned out the battery was below the charging threshold but I used a 12v to jump it and got it working again
댓글 달기
귀하의 답변을 추가하세요
phil bailey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 672
