Msg "insert SD card again" or "try another card" msg when inserting m
Msg "insert SD card again" or "try another card" when inserting memory card; for all cards. ???
좋은 질문입니까?
좋은 질문입니까?
Had that too. The SD slot got stretched a little when a card got stuck once and I pulled it out with a screwdriver. Solution was to add a little thickness to the SD card. Otherwise the metal contacts on the card don't touch the inside connectors ;-)
이 답변이 도움이 되었나요?
What do you mean add thickness?
Add some layers of duct tape, for example, on the side w/o contacts.
If methods of @hellofellow won’t help, go to repair shop ans ask to diagnose SD Card slot, ribbon cable and MoBo. Changing slot might help.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 3,404
