주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and disassembly information for laptops manufactured by ASUS.
Keyboard not working or typing?
Barely stepped on the edge of the computer and now the keyboard won't type. Lights up and the laptop turns on and everything but no type function. Help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
does it work with a USB mouse and keyboard ?
Austin Harris what model is it and where did you step on? Bottom or top case?
I,m kowtham and I'have ASUS X540S model and it's keyboard not working and that particularly keys like k f d b r why I don't know please tell me any thing about it.
댓글 달기
답변 3개
가장 유용한 답변
Austin Harris use a USB keyboard and see if that works. If so, it is most likely that you either have a broken keyboard or a broken connector on your board. You will have to disassemble your laptop to check on that.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thank you again!!! It needs a new keyboard. Don't suppose you could link the correct part for me??
Not unless we know what model your laptop is :-))
댓글 달기
It may or may not fix the particular issue in this case, but I just had the same thing happen and got it worked out, so posting just in case.
I’ve had this issue literally a few moments ago, as well as on the MSI laptop I had for less than a year. Basically all i did was to restart the stupid thing. My keyboard was lit up and typing fine one moment, but then suddenly in the middle of a sentence it wouldn’t register a key stroke on any program I had open. Restarting fixed it.
A lot of people are having that issue lately, especially if you’re on Windows 10. So, if you have problems with it, quickest way to try a fix is restarting and seeing if that does it. Not sure why it does to begin with though..
But, yeeeeah, I miss my MSI...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
you may have stepped on a key and held it too long therefore activating the Sticky or filter keys or other optional keyboard settings.
Try this first before you get into all the hardware fixes:
Method 1: Disable the Filter keys and check if it works.
a: Type Ease of access in the start search box and hit enter.
b: Now click Change how your keyboard works
c: Remove the check mark from the box next to Turn on FilterKeys.
d: Click the blue Set Up FilterKeys link
e: Underneath Keyboard shortcut, remove the check mark from the box next to Turn on FilterKeys when right SHIFT is pressed for 8 seconds.
f: Now click Ok two times.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Austin Harris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 7
지난 30일: 14
전체 시간: 11,759
