주요 콘텐츠로 건너뛰기
13인치 디스플레이가 장착된 MacBook Air 모델에 대한 수리 안내서, 지원 및 문제 해결 정보입니다.
3666 질문 전체 보기
What is this capacitor was burned in the logic board
Hello,
we have a macbook air 2015 13", the macbook is not turning on, but it has a burnt smell. we checked the logic board and saw one of the capacitor was burned.
we would like to replace this, but we cant find in the google "NEd AV7 "capacitor..
thank you for your answers.
Tibor
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Best way to get that one is from a donor board.
That would be C 7621
62UF 0 023 OHM 20% 11V TANT-POLY ASE-B2S
Just before replacing that capacitor you need to find the cause of the problem. That capacitor sits on a 6 V line that got a electrical load of more than that.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
If you don't have any donor boards, check mouser or farnell (mouser has a bigger range in components, farnell does free shipping :))
but like Oros said, could be more problems then just this cap.
Kind regards,
Tom
Hola me gustaría que me ayudara, tengo un problema tengo una macbook air y se apaga cuando va cargando el SO pienso que debe ser un capacitor pero me gustaría sus valores para verificar bien.
댓글 달기
귀하의 답변을 추가하세요
Iphoneszerviz Szeged 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 2,115
