주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 질문 전체 보기
Connect iPod 4rd gen with MacBook Pro 2015
Hello,
I have an old iPod 4rd gen which i want to reactivate, because it fully works.
The problem is that i had an old PC with firewire slot and now i have only Mac Book Pro from 2015 that has only USB and Thunderbolt slots. Also, iTunes sends a message like "Cannot connect your iPod with USB cable, please connect it over Firewire".
Is there a way to connect the aforementioned iPod with this Mac?
Will Firewire-to-USB adapter do the job?
Thanks,
Regards,
Dragan
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
This question was migrated from http://meta.ifixit.com/Answers.
댓글 달기
답변 1개
가장 유용한 답변
Dragan Basta Since it is a fourth generation it definitely will require a Firewire wall adapter to finalize a restore. It will NOT restore through USB! You can get those of ebay and many other places. Once properly restored it should sync through USB ports. Sometimes installing an older version of iTunes will support your iPod. Yes, a Firewire-to-USB adapter should work but may not be necessary to do the job. I still use a 3rd gen and 4th gen iPod and have no issues syncing via USB
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Actually, see if Firewire to Thunderbolt works. This has better reviews on Amazon vs the USB to Firewire adapters.
https://www.amazon.com/Apple-Thunderbolt...
댓글 달기
귀하의 답변을 추가하세요
Dragan Basta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 146
