주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for many cameras in the PowerShot Line.
Camera wont turn on
My Canon PowerShot SX610 HS camera isn't turning on after a canoe trip. I have it in rice right now. is there anything I should do? i also heard a weird crackling noise right before i turned it on. if that helps
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Well, Im allready doing that! hah
댓글 달기
답변 1개
선택된 해법
@redboyryanyt you do want to take it out of the rice. Rice does not do anything. It does not prevent corrosion, it will not repair your camera. The rice is wasting your time that you could spend trying to fix your camera. do not turn your camera on or try to do anything with it. Remove the batteries. weird crackling noise could be caused by the water on your circuitry cooking and shorting out components leaving your camera dead for good.
For now, remove the battery. Then disassemble your camera. Even so there are no specific guides for it, the PowerShot series all disassemble pretty much the same way. Take lots of pictures and separate your parts. These guides should at least get you into the camera. Once you have the camera disassembled, clean everything with 90%+ isopropyl alcohol and a soft brush. Remove the EMI shields of the circuit boards since the water will accumulate under that. Clean all connector and cable ends. Check the boards for obviously damaged or missing components. Only after it is all cleaned and dried do you want to reassemble it and replace the battery. Do not reuse your batteries. With all that done, try to troubleshoot your camera for further damage if necessary. Just like any other device, water damage is the hardest to repair and to trouble shoot since virtually any part may have failed.
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
Im actually doing that right now lol
Excellent. Let us know it is is coming along.
Ok, so one thing i did notice was a chip by the left side of the main Board *with the USB port facing down* that there was a bit of something. The Isopropyl got rid of it. So could that be corrosion or something like dust?
Could have been. Should have taken a picture:-) so we could have checked. Remember to clean absolutely everything on your camera.
Im reasembling it now. I got most of it cleaned, it didnt look like anything else had Corosion on it. I hope it works :D
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Ryan Kirby 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 3,844
