주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
542 질문 전체 보기
My computer desktop will not display.
when I power up my computer the display turns white and nothing displays. I"m told at the genius bar that I need to replace my logic board because of enlarged or blown capacitors. If so they want a large amt of money for the part and labor. I have grown very attached to this computer and would like to save it but the cost is a little over the top any suggestions how I can get this repair made at a reasonable price? I looked at a step by step guide on this site and while I'm not the most computer literate person I think I might be able to do this myself with a little help which in the grand scheme of things saves me about 150.00 and makes it more reasonable. How do I know that this is the only thing wrong with the computer?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Hi Larry, when you boot the machine do you hear the chime, the fans, the hard drive loading or there's no activity at all ? If there's a hard drive activity you may connect an external monitor to your imac and check if you have video on it cause the problem could be a video cable issue or a LCD issue.
An other possibility would be a failing hard drive so you could try to boot from your installation disk or from an external hard drive. Did you try the pram and PMU resets ?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
larry Waddle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,091
