How to connect/disconnect ribbon cable from an OLD FFC connector?
SOLVED
Edit 2: Second picture shows somewhat manipulated tabs pressed back into place, seeming to function well without needing to solder.
Edit: I've attached an image of the connector with the clip removed.
I've been troubleshooting my brother's old bass amp and decided to disconnect the DSP effects board to work on it easier.. That was a breeze; pressing down the individual locking tabs to open the outdated FFC connector. However, reconnecting seems impossible now. If anybody is familiar with old connector part numbers, it is stamped with "MXT52011"
It's an 8-pos connector using the old spring contacts. The amp is rather old and has been worked on in the past, as I'd noticed there were some tabs broken off of the connector, though this does not affect functionality. It's important to note that each contact opens separate from the rest; there is no single tab or flap to lock/unlock. There is a clip that slides over each side of the connector, though it plays no part in locking the FFC into place.
I'd greatly appreciate a quick response as this project has been frustrating me. I'm almost sure that I have the fault fixed, but I cannot test it fully without reconnecting the DSP effects board. If I can't find the solution I need, I'll probably end up having to replace the connector. /:
좋은 질문 입니까?
