주요 콘텐츠로 건너뛰기
Is it safe for keyboard lights to be always on?
Im currently using Lenovo 720S , 13 inch.
its my first time to use an ultrabook. anyhow ive used laptops before with backlit keyboard that you can customize to turn it off 30-second to 360 seconds if not being used or simply idle depending on your settings.
now the funny thing is that the keyboard lights of my laptop can't be customized or simply just stay always on all the time even if im idle though you can certainly turn it off manually.
my question though is that is it safe or okay to keep the keyboard lights on as I leave my laptop always on 24/7 as my work always involve with emails?
or should i turn it off manually as i go to bed? (fn+spacebar)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi @islush ,
It should be perfectly fine to leave them on, as the system has been designed for them, however it may be that the "light" from the keyboard may be disturbing to you at night.
You can if you wish dim the lights rather than turn them off. According to the User Guide on p.4 it appears that the lights cycle through off - dim- bright -off when pressing the space bar (with Fn).
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
waw, that was quick.
I really appreciate for the prompt response.
Anyhow thank you very much for the information.
my only concern is the lifespan of the keyboard lights will be decreased since i leave it on.
anyhow this answers everything i need that its okay not to turn it off :)
though of course, their are times that i need to shut it down to let the machine rest lol. (i did on my previous laptop, 3 months straight without turning it off)
Hi @islush
Nowadays the lights are just LED chips so their lifespan is what you'd expect from LEDs i.e. longer than the laptop most probably
댓글 달기
lights do drain battery significantly so turning them off is a necessity.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Edgar Allen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 4,608
