주요 콘텐츠로 건너뛰기
모델 번호 K430T로 식별, 2016년 1월 출시. 스크린 유형은 16M 컬러 IPS LCD 정전식 터치스크린과 13-megapixel 카메라를 장착하고 있습니다.
20 질문 전체 보기
Why is my phone super slow
my phone is running slow and also exiting anything I'll be on or using and the keyboard can't even remotely keep up with typing. And how do I fix it
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi,
Download, install and run the following 2 apps. Do one at a time obviously.
The first will check for malware on your phone while the second checks for viruses.
Once you have run both and cleared any problems brought up by the apps and you are still having the problem, I suggest that you back up the phone using the phone's backup feature and then perform a factory restore of the phone.
Be aware that a factory restore (or reset) will restore the phone to it's default condition. It will be like when you first bought it. It will erase all your data and downloaded apps. , that is why it is important to do a backup first.
Once the reset has been completed see how the phone behaves. If it now acting normally perhaps a downloaded app may be the cause of the problem.
Restore the phone from the backup you made earlier using the phone's restore feature. Once the restore has been completed check how the phone behaves. If it is still behaving normally then the reset has fixed the problem. If it is again acting sluggishly a downloaded app is the problem The trick is to find out which one. You will have to uninstall each downloaded app one by one and test the phone between each uninstallation to see if the problem has been resolved and which app was the cause of the problem.
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I hope this work and
댓글 달기
no changes... the same less speed on 4G connection...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shad Bettis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 8
전체 시간: 4,098
