How do I correct the error message "please press shutter again"?
When I press the shutter button it makes a dragging sound and I get the error message, "press shutter button again". How do I repair this ??
좋은 질문 입니까?
좋은 질문 입니까?
Here's how to fix it:
해당 답변은 도움이 되었습니까?
The D5200 is designed differently so popping the back and bottom off did not get me to the little red gear. I probably have close to 100,000 actuations on it-is it worth sending it to the factory or should I start shopping??
@arwxguy seems to be an issues with Nikon's DSLR camera. You want to go ahead and check a few things like:
1.Ensure the battery is charged
2.Remove battery for a few hours then replace.
3.Remove and replace lens or put a different lens on camera.
4.Remove and replace memory card or put a different memory card in camera.
5.Is the viewfinder dark? Mirror may be stuck up.
6.Stuck shutter release motor
If its still under Nikon warrantee, you should let Nikon fix it. If it is not then take a look on hereDifferent camera, same issues and same fix.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,792
