주요 콘텐츠로 건너뛰기
Hewlett-Packard began manufacturing personal laptop computers in 1993.
3329 질문 전체 보기
Some keys not working on my laptop
It's an older laptop, roughly 5-6 years old. It's an HP Pavilion DV6-6135DX model with Windows 7.
Just yesterday, the keys of "S, D, F, J, K, L, ;, and Enter" started not working (I never spilled anything at all though). Since then, they have worked intermittently but getting worse to the point of them not responding at all. I have tried everything I can think of by searching online for help but to no avail. I have tried a system restore, uninstalling the keyboard driver and restarting my computer, unplugging my computer and holding down the power key for a long time, taking off the keys and wiping the area down with rubbing alcohol to clean them with a paper towel, using a blowdryer to get any type of crumbs out, etc. I don't have an external keyboard on hand to even try that option. I did run the EOS Mode or whatever it's called and the same keys didn't work on there either if that helps you.
I don't have QTips or a can of air to try getting even more in depth but I'm not even sure if that is the problem anymore.
Can anyone please help me troubleshoot this? I went ahead and bought a replacement keyboard on Ebay for $18 but I'm not even sure if that will work. I have to learn how to install it myself, don't know how to do that either.
Please help!! Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 6개
Thanks OldTurkey! But it looks like it starts on page 71 and not page 78 unless I'm missing something? Also do you think your guide is better to reference or this YouTube video I found? https://www.youtube.com/watch?v=PMd8aBwF...
Also, do you think this is a doable job for me to even do myself? I dont have much experience trying to fix electronics.
Bump, thanks
Bump again, thanks
Also, is it still a sign of only a bad keyboard that needs replaced if those letters start working every now and then? But then eventually go away again? Currently right now I'm using them fine and it's like there are no issues but they will go away again soon like before...This has happened on a few occasions?
Bump, thanks.
댓글 1개 더보기
댓글 달기
답변 3개
가장 유용한 답변
@bd3616 sounds like a bad keyboard. Download the service manual for your computer from here. Page 78 will show you how to replace it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
bro this fix will work just press number keys rapidly and crazily for some time
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
just crazzily press number keys
Bro thank you so much man.
댓글 달기
Did you find a solution for your problem because I'm facing the same problem? Its goes off on occasions and then work again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
just press number keys rapidly for some time
댓글 달기
귀하의 답변을 추가하세요
bd3616 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 8,918
