주요 콘텐츠로 건너뛰기
The Sony Playstation 2 SCPH-790xx is the fourth revision of the Playstation2 slimline model.
11 질문 전체 보기
Correct cable for SCPH-79003 power/reset?
I need to replace the cable and I've been looking for one online....
Will this cable work when trimmed down to 8pin? : http://amzn.to/2xK7EVU
I bought this one from eBay which works but turned out being too short in length : http://ebay.eu/2hC1z9G
thanks for any help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
@tonictinsk what is the exact model number for your PS2?
댓글 달기
답변 1개
선택된 답변
@tonictinsk apparently there are a few version of the cable out there. This one is the long version for the SCPH-79001 version which will also work with the European SCPH-79003 version.
It is possible that the first cable would work if you trim it, but I'd be careful with that since you do not know if any wires are crossing etc You will need to know the spacing between the wires to fit your connector. You can of course always try it out and let us know if it worked. You'd only be out a few £
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
@oldturkey03 can confirm first cable works after trimming it down! very relieved as it required a lot of patience. The cable is quite long aswell so had to tape it down.
Here's a few photos: https://photos.app.goo.gl/SxDlUo1pmuQHFM...
@tonictinsk excellent! Glad to you've tried it.
댓글 달기
귀하의 답변을 추가하세요
Anthony 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 279
