주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
Prohibition Sign on Start Up
iMac won't start up and it shows the "Prohibition Sign" on start up. I went into recovery mode and to disk utility and it doesn't show my fusion drive and it shows no information what so ever. Can anyone help me?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
You won't see the Fusion Drive under Disk First Aid, You'll see the discreet drives (HDD & SSD) that combined make up the Fusion Drive set. If you can't mount the drives then you have a deeper problem!
At this point you'll need to use the command line interface of Core Storage following this guide: Fixing a Mac Fusion Drive that Disk Utility can’t erase
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Sounds like your fusion drive has failed.
Try to get ahold of another mac and make a bootable thumb drive for any OS X installer. See if your iMac will boot from this thumb drive. This would verify if your disk has failed or not.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Name 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 269
