주요 콘텐츠로 건너뛰기
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 질문 전체 보기
Can I fix a hole in my radiator, or do I need a new one?
I think the answer to this one is going to be "no,' but if you don'task, the answer is always "no!"
After weeks of procrastination, hours of stripped-bolt frustration, and a brief period of euphoria when I successfully replaced my thermostat, I attempted to reattach the hose to the top right of my radiator, as one does. In shoving it on there, I managed to rip off the hose connector and surrounding radiator completely. There is a hole about 2.5 inches radius where my radiator would attach to the hose.
Can I glue the stuffing outta this until I have the money to replace the radiator? Can I just replace the top plastic part where the hose should attach?
I need it to drive 30 minutes each way from work, about 15 miles at the outside.
Update (10/02/2017)
These are pictures of the problem.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Thanks for the response, Blake. I was going to try some 500* epoxy on it, but I wouldn't want to cause further damage than is already done, so I think I will wait until I can get the new one. At least a new radiator isn't as bad as replacing my head gasket could have been!
I tried something similar on my A4 Audi, and it just blew out at work and I needed a tow home and a new pipe. My advice if in doubt don't!
댓글 달기
답변 2개
선택된 답변
Hi Cassy, the problem with trying to repair it is preventing anything, such as epoxy, from getting inside the radiator and then having it flow into your engine. I would suggest replacing it with either a good used one if you are in a financial pinch but new would be the best option.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
True Dat as Klein says above. In any case, no epoxy will withstand the heat cycling that a plastic radiator sees. Replacement is the only safe option. They are not very expensive. Nissens, a Danish company makes radiators for our cars. I have one on my 300CD and believe it to be better quality than the OE.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cassy BoBassy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 4,497
