주요 콘텐츠로 건너뛰기
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
Change to lightning port?
I have a 3rd generation ipad (Wifi + Cellular). I would like to know if it's possible to tear it down and install the components into a iPad 4 case and modify my components for the lightning connector?
Thanks
Matt
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
No, the flex for these two connector types are different and would not work properly from one logic board to another. While they look similar, minus the different form factor for the actual dock, they are completely different electrically.
iPad 3 Dock
iPad 4 Dock
Fix problems with USB data connections and charging problems by replacing a damaged, dirty, or corroded dock connector and its cable assembly in an iPad 3. 이미지
제품
iPad 3 Dock Connector
$19.99
Replace a lightning connector compatible with the 4th Generation iPad Retina model A1458, A1459, and A1460. Fix problems with charging and data transfer. 이미지
제품
iPad 4 Lightning Connector
$19.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Matt White 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 122
