주요 콘텐츠로 건너뛰기
Help on charging port repair
My speaker wont charge and i opened it up. Once open i saw a red wire that wad not attached to anything and i cant see where it must go. The inside of the charching port had a plastic inside that also fell out. Where should the wire go and should i replace the entire charging port or can i just put it back?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 10개:
You can add a different charging port.... After all it will function the same thing
the red cable is the antenna bru
How do I open the carry handle screws?
I also cannot get the carry handle screw off , please can you assist
How did you take off the 2 big handle screws on the Blaster? Cannot get the big ones off
댓글 5개 더보기
댓글 달기
답변 4개
@jolsteryes you will need to replace the charging port. Obviously it is soldered to the board so you will need to have the right tools to replace it. Check digikey.com or mouser.com for replacements. You'll need to do some searching for it but it looks like a standard connector.
As for your red wire. It looks like it is on your board so the other end will either have to go to a switch, the battery or the speaker itself. On picture number 1 it looks like there is only one wire connected to the speaker. May need a clearer picture..
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The read wire is the fm antenna. Leave the other end free, unconnected.
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
it is an antena for the bleutooth
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Anyone got a circuit diagram on this equipment please.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Anyone got a diagram for this equipment please
댓글 달기
귀하의 답변을 추가하세요
Jolster Theron 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 32
전체 시간: 13,995
