주요 콘텐츠로 건너뛰기
Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
37 질문 전체 보기
My phone is unable to connect to mobile networks, probably hardware issue
My phone is unable to connect to mobile network and it is probably hardware issue, cause i flashed everything twice.( I mean os) it occured with signal going for short time then came back again but now no signal at all...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
so there is a few things that can be the cause of your symptoms.
1) Be sure to make sure the device is either unlocked, or locked to your carrier.
2) Look into the national blacklist. If you got the device second hand, there is a chance it was reported stolen.
3) Software corruption. Run a factory reset on the device.
4) Disconnect. Make sure there is enough pressure on the metal traces lining the housings, to the board.
5) Coaxial breaks. Look for coaxial cables, test continuity, and replace them as needed. (make sure they arent loose first)
6) Antenna failure. Check for board antennas. sometimes a reflow of these parts will fix the issue.
7) Network IC failure. Board level failure is pretty common. you will need experience with SMT to replace the Components in the networking Circuit. most people will scrap at this level of failure.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ahmad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 11
전체 시간: 112
