주요 콘텐츠로 건너뛰기
2009-2012년 사이 제작된 13” 화면 Unibody MacBook Pro 모델.
4630 질문 전체 보기
Grey screen death. Hard drive (SSD) or hard drive cable?
Hi.
Approximatly a week ago my mac shut down. When i started my computer, i got to the login phase, but during the login a lot of text came upon the screen and the mac shut itself down.
I did a apple hardware test and got this result: 4hdd/11/40000004:SATA(0,0)
I then erased the hard drive and tried installing osx. It did not work by network, so I installed os x high sierra by USB. After the installation i tried to turn the computer on. There it ended with a grey screen, and now i am stuck.
I got an SSD as a Hard drive.
Very grateful for any help possible!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Exactly which machine do you have and what type of SSD?
I got the macbook pro unibody mid 2012. SSD disk: Samsung 850 EVO Series MZ-75E250B 250GB
댓글 달기
답변 2개
It's possible it could be a logic board issue. Have you tried running disk utility first aid when you plugged in the USB?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
My hard drive does not even show up in disk utility.
If it does not show up more then likely you have a faulty hard drive. If you have an extra one to test it try a spare & see if you can boot into osx.
댓글 달기
This error you see (4hdd/11/40000004:SATA(0,0)) means you need a new hard drive. If you recently replaced it, check to make sure that the SATA cord is plugged in, and the drive is installed correctly. If not, then I would suggest looking into buying a new SSD and replacing it, or taking it to a repair service to get it replaced.
For more information, you can check out a similar question asked:
Try reinstalling osx again, or replace HDD?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
It can be the hard drive cable?
There's a slim chance it could be if it's improperly connected, but I wouldn't put my money on it. Most likely, you'll have to get a new hard drive.
댓글 달기
귀하의 답변을 추가하세요
Sindre Fjellestad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 1,281
