Replacing my PCI-e SSD.
Hello,
Im running out of space, and i'm looking into replacing my SSD for a higher capacity, is that possible? If it is what Brands and models are compatible.
Current SSD is APPLE SSD SM0512F 512GB.
좋은 질문입니까?
Hello,
좋은 질문입니까?
The idea here is to setup a dual drive system (SSD & HD). The SSD will have your OS and apps and the second drive would be for your files (music, pics & vids). You'll likely want to compose vids & music off of the SSD then save your work over to the HD.
This way you're maxing your dollar as HD's (even a SSHD) is cheaper than an SSD.
Yes, you still could put in a SSD but you won't really leverage it as you'll want to use the still faster SSD as your boot drive (the PCIe blade SSD).
If you really want the SSD you'll need an adapter frame like this one: OWC 2.5" to 3.5" Drive Adapter Bracket and you'll still need the in-line thermal sensor i listed above.
이 답변이 도움이 되었나요?
Why not just add a hard drive for storage?
이 답변이 도움이 되었나요?
I agree a much better solution!
Would an SSD work instead?
Almost forgot! You'll need this as well with your new drive: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later as only the Apple drives have the sensor built-in.
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 338
