주요 콘텐츠로 건너뛰기
Repair information for the Gaggia Classic Espresso Machine.
19 질문 전체 보기
Not enough water pressure to force through the pod
Unit comes on, when ready to force water through the pod, the unit sounds like it goes to half power. Made sure pod isn’t too tightly packed. Regularly descale the machine, hoses are clear, unit is primed, just very little water pressure. What is the issue?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Why don't we see if this solves your problem
https://m.youtube.com/watch?v=Ghti27dMZb...
해당 답변은 도움이 되었습니까?
점수 3
2 댓글:
@oldturkey03 thanks. I had good teachers!
댓글 달기
@shammond86 you definitely want to check all parts for obstructions caused by debris or buildup. If all that looks good and is clean you need to consider bad hoses or a pumps issue.
shows a typical water circuit for the Gaggia
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Susan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 5,807
