주요 콘텐츠로 건너뛰기
What is the best portable battery for 3-4 recharges?Dell Inspiron 7559
When i bought this laptop i expected a battery life of 10 hours, but only with a browser on, it drains within an hour and barely goes on for 2 hours with battery saver on.
So now i wanted to go out and relax and use my laptop for at least 3-4 hours.
Can anyone suggest a good portable battery charger ?
Also how much should power battery should i get?
My specifications are :-
nstalled batteries
Information about each currently installed battery
BATTERY 1
NAME Dell
MANUFACTURER SIMPLO
SERIAL NUMBER 1642
CHEMISTRY PBAC
DESIGN CAPACITY 73,997 mWh
FULL CHARGE CAPACITY 70,589 mWh
CYCLE COUNT -
Let me rephrase : -
What battery should i select from Amazon with my specifications ? I don't understand the convention of mWH and mAH. They require voltage to be convertible and i don't know which one to take
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
@gildesh my concern would be why your computer is using 6amps an hour if you are only using your browser. Sounds like you have a bad battery and instead of using a portable charger, I'd replace the battery. Something like this should work for you.
Update (10/20/2017)
@gildesh just did some research on your computer. It is far from your expected runtime of 10 hours battery. Here is some of the data that reflects why it does not last longer than 2hours max:
Power Consumption (in Watts)
Idle Minimum 9.4
Idle Average 14.4
Idle Maximum 15
Load Average 102
Load Maximum 120
So the Dell Inspiron 15 7559 has a battery runtime of ~232 min +/- 9% Information from here
The biggest challenge here seems to be the CPU/GPU combination. Your battery time will not get better. Also keep in mind that your AC adapter (I do not know how many Amps it delivers) may not be sufficient enough to cover the power usage of your computer and your battery may get drained even so you have your computer plugged in.
Something like this will give you about 3-4hours of time.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Okay, this might sound amateur, but how can i be sure that it will work? I mean i brought this computer from Amazon with decent reviews (both number of and quality of) yet it has a crappy one.
One guy told me that it is the Dell Inspiron 7559's faulty structure which is the cause of this.
oldturkey03, mate please!!! help
@gildesh check the updated answer
The charger actually works fine. IT charges really quick but iam looking at your suggestion. Thanks!
댓글 달기
가장 유용한 답변
Hi!
Dell themselves are selling some kind of portable battery for their laptops if I'm not mistaken. However it's not really large enough to charge your laptop more than once... You'd be lucky actually to get it to charge all the way with this thing. And it's fairly expensive, too. The link will be below. Laptops simply weren't built to be recharged using power banks.
http://www.dell.com/en-us/work/shop/dell...
PS: A great way to extend your battery life is to lower your screen's brightness (on your laptop you can do that with Fn+F11). If you drop it down to something like 50-60% you'll see a noticeable improvement.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Kindly re-look the question. I added a small part at the end.
Okay...sorry unable to comprehend the language. Can you post the english version and more importantly, confirm whether that power bank would go on for at least 3-4 hours? (if its a powerbank)
@gildesh yes it is. It delivers 18000mAh and your computer. According to your computer draining the battery in one hour, this bank would last for about 3 hours.
댓글 달기
귀하의 답변을 추가하세요
Abhay Saini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 343
