주요 콘텐츠로 건너뛰기
Advanced GPS for Trucks, released in 2015, equipped with voice control and can easily be used on any truck.
8 질문 전체 보기
Why is my Garmin DEZL dEAD
Garmin DEZL Totally Dead
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
@massey188 what have you checked? How did it die? Did it work before and then one day......? You checked the power to it?
been a couple of month without using it , my gps when putted on ,show garmin logo, become brighter and shut down immediatly , been fully charged and i putted a new battery ( i thought that was the problem , but it wasn't and tried to reset without result any idea ?
댓글 달기
답변 2개
가장 유용한 답변
@massey188 check the power to the GPS. Make sure that it is properly connected to an external power source. After that, you want to use these guides to work on it. Check the charging/power port and make sure that ti is properly connected and has power going to it. Check the motherboard for any obvious damaged or missing parts. Post some images of what you see with your question. 기존 질문에 이미지 추가하기 That way we can see what you see and can try to assist you further if needed.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
having this problem , i changed the battery and cleaned all contact , battery charged during 48 hours and exactly the same problem occured , garmin logo show, suddenly become brighter and shut off
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gerard Harkin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 513
