주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
half screen light up after replace display
Hi There!
I've changed the display of my iphone and after reassembled the screen lights on only left side and right side is fully dark. The sensor works normaly and touch Works as well but no back light on this side. Any clue?? Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Try to unplug it and plug it in again. Or maybe the backlight shorted out.
If you have any questions or concerns please comment below! Thank you
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Hi Walker, Thanks for your tip. Another question is: Why, after changing the display and wearing a sunglass with polarized lenses the screeen turns black following the main function of those lenses. My curiosity is: Why this behavior is happeing now and with original display didn't? Any clue?? Thanks in advance. Rgds
Marco
You do realize a LCD screen leverages polarized light to function. The light source is directed at the screen north to south from the back. The LCD blocks the light north to south when not turned on. When the LCD cell is activated the light is twisted east to west which allows the light to pass through the colored filter outwards to you. Your sunglasses maybe also set east to west so the now west to west light is blocked. If you turn the sunglasses north to south the polarization of the light won't be blocked. Here's a bit more: Polarization & TFT / LCD Monitor - How it works! (3D Animation) Vid
Thank you man. Very good come to the class. Appreciated.
댓글 달기
가장 유용한 답변
Marco, it sounds like you have a low quality replacement screen. If you connect the original screen, do you have the same backlight issue? If not, then it's definately the screen. Additionally, the polarizing filter was installed incorrectly and that is why you can't seen anything with sunglasses.
If the original screen also has the same issue, then your problem is on the logic board, specifically the cathode filters. That would require a micro-soldering repair.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Hi Minho. When you mention "incorrect install of polarizing filter" what are you talking about exactly? Where is located this filter which I may be installed incorectly? In fact I haven't heard about this on researches. Thanks in advnce + Rgds. Marco
The polarizing filter is installed between the LCD and screen when the screen assembly is assembled/manufactured. If it was incorrectly installed, it will cause the problem you have identified.
So, there´s no action on my end which might cause such issue. Thanks for your prompt response. Rgds
댓글 달기
Yes, I would say you didn't power off the phone or disconnect the battery when changing the screen and shorted the backlight circuit. But wait...Is this a 6 or the 6 Plus?? Also, did you power it off? Unplug Battery??
I know it is possible to also damage the little lights that light up your screen but that's unlikely.
Also, Does your old screen work (To test with) or is it out completely?
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hi Michael. First of all thaks for your answer, help and attention. As for the battery, it was disconnected mostly because I changed both at a time. Display and battery. As our good friend Minho said above, it's most like a low quality screen than any other issue. I'm trying on my first opprtunity to resume the old display back to the iphone and perform tests to check out whether could be any problem on the main circuit board, but in advance I'd say it isn't. Anyway I shall try it out then have some additional information about. I'll be back here even to share the experience only.
댓글 달기
귀하의 답변을 추가하세요
Marco Bella Rosa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 540
