Why is there no power to the iron. No indicator light on.
Whilst ironing the power light went off and iron stop working.
좋은 질문 입니까?
좋은 질문 입니까?
Many of the UK heating devices have a fuse within the plug. Carefully open the plug to gain access to the fuse. Here's an image of the plug assembly from the Morphy Richards Iron Teardown:
While not stated you'll see the far left & right connectors are also the fuse clips. With an Ohm or continuity tester you should see these are connected (with a fuse in place), If not you need a new fuse.
해당 답변은 도움이 되었습니까?
1. check the cord
2. there is a fuse in the steam iron press, get it replaced by service centre.
4. Thermostat is not working.
4. heating rod is damage.
해당 답변은 도움이 되었습니까?
Where can I get my iron seen to ? Rescaled it now won’t come on just keeps going off checked fuse new fuse in but still not coming on !
24 시간 전: 23
7일 전: 106
30일 전: 391
전체 시간: 26,958
댓글 3개
I have lefty iron forgot to turn off just noticed but the iron is off and now won't work
Susan Bracken 의
I’ve a steam iron generator it’s stopped workin the light doesn’t come on no heat nothing can u help?
tina.kavanagh@hotmail.co.uk 의
My iron won’t switch on .. change the fuse
roseann01 의
