주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
iPhone is not responding at all
Hi guys,
i recently bought an iphone 6s 16gb from ebay and the description said that it has power problems (not powering up at all). The phone doesn't have an iCloud lock and it is not blacklisted, so i grab the opportunity to try repairing it.
I received the phone and i tried to turn it on, but it is not responding. I plugged it into the wall charger, but nothing happens, although i leave it there for over an hour.
I plugged it to my Mac but nothing happens again and iTunes doesn't recognize it.
I also plugged to a windows pc, but nothing happens again.
I tried to hard reset it, but no respond again.
I also tried to put it in DFU mode, but nothing happened.
'The only sign is that it gets hot when i plugged it to the wall charger.
Do you have any idea, what the problem is?
Is there any way to find out if my logic board is damaged?
Is there any possibility that a battery replacement will short out the problem?
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I would just return it. How much was it?
댓글 달기
답변 1개
선택된 해법
Hi Dennis, based on what you say there is a very high probability that the problem is on the logic board. Buying "broken" phones on eBay is usually bad news because these can be phones that no one can fix and then get unloaded on unsuspecting buyers. At least in this case, you kinda knew what you were getting into.
The first thing I would do is to open up your device and do a quick visual inspection. Look to see if the water indicator stickers have turned red. If they have...you may be in for a rough ride :>). Also look to see if there are any missing screws, brackets, torn flexes or any obvious signs of tampering/repair. I once received a phone from someone in Africa for repair only to find out that the previous tech had raided it for parts to the point where it needed to be completely rebuilt before even trying to repair.
If everything looks okay, then measure the voltage of the battery directly with a multimeter. Any voltage less than 2.75 - 3V will not be enough to boot the phone. Report back so we can take the next step. Make sure to comment on this answer otherwise I won't be notified.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Thanks a lot for your fast reply!!! I'll let you know as fast as possible!
댓글 달기
답변을 추가하세요
Dennis Kolotouros 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 164
