주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toyota's fifth generation Pickup
30 amp fusible link blown
The fuse box under the hood has a 30 amp fusible link that is blown. I replaced it and blew again, and was told by friend to replace the fuel pump. Engine turned and problem seemed to be solved but happened again when I closed the hood. Found the right turn signal had a blown wire just behind the light. Since the fuse has not blown but I am waiting for it to happen again.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@estgarcia85 since it is working for now you may just have resolved that issue. If it happens again, you'll have to check again. Problems like this are really hard to resolve since there is always more than one possibility. Post a picture of this "fuse box under the hood has a 30 amp fusible link" with your question so that we can check the wiring diagram. Use this guide to post images with your question 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Esteban Garcia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 15
전체 시간: 857
