주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
I have a vertical lines on my iPhone without being smashed or anything
I have changed the screen and it appears again
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
If you could post a photo it'd give us more idea.
I have posted one
If it's exactly the same as with a different screen I'd guess the connector connecting the screen to the main board might be a damaged or dirty or not properly seated, or you've got a faulty main board, or you've somehow managed to damage the new screen or its ribbon in the same way through mis-installation. (Though in the latter case the pattern of stripes would almost certainly be slightly different.)
댓글 달기
답변 1개
가장 유용한 답변
It sounds like it could possibly be something wrong with the connectors on the logic board itself. Does it look like any pins are missing? May have to use a magnifying glass to see.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Khaled Serag 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 462
