주요 콘텐츠로 건너뛰기
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
46 질문 전체 보기
Where do I find the positive and negative power sources on the board?
I am looking for power sources on the GameCube Controller motherboard. I need a positive and negative so I can connect some joystick LED's but I don't know where they are. Could anyone help me? I have two wires that I need to solder I just don't know where I need to solder them. Any help is appreciated.
Here's an image of LED Joysticks on PS4 controllers. It's the same concept but I want to do this with GameCube Controllers.
https://imgur.com/Kjmelo1 - Controller
https://imgur.com/ojsBInk - LED
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
@zad what you need to do is to post an image of your circuit board so we can point out where to solder to. It is one thing to look at what you want to do but you need to help us to help you. Use this guide 기존 질문에 이미지 추가하기 to do so.
Use your multimeter and trace where pin 1 terminates on the board. Pin 1 carries 5V and pins 2 and 5 are ground.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Zad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 865
