주요 콘텐츠로 건너뛰기
Repair and service information for the Lenovo IdeaPad 305. Released in 2015, the Lenovo IdeaPad 305 line consists of 3 bright colors and Dolby Advanced Audio.
4 질문 전체 보기
Idea pad 305 wont charge
i have had my idea pad 305 for just over a year i purchased for a project which then never happened. i used it for emails and a few other bit for a short while. I then started using it when i needed to put parental controls on the family windows 10.
It ran out of power so i connected the charger and it never charged regardless of how long i left it charging. i then borrowed a charger from work which worked, it ran out of power again i used the work charger again and it wont charge at all i have since purchased a new charger and that does not work either.
Any help would be greatfully received.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
@pridu99 sounds like your battery is the problem. Most likely from the long time of having been discharged and now no longer holds a charge. Replace it and re-evaluate
이 답변이 도움이 되었나요?
점수 2
댓글 달기
OMG!!
you would not believe it. I borrowed the work lead again and pushed it in quite firmly and it started working. I tried both the original and the recently purchased leads but they still wouldn't work. we tried all combinations too to ensure it wasn't anything really daft. I decided it must be the connectors and on really close inspection found that the work one was just over one millimeter longer than the other two. I shaved the plastic off the end of one and now its perfect.
Sorry to have wasted your time.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Is it possible that the bit inside my laptop that the charger goes in to could be broken
댓글 달기
답변을 추가하세요
Barry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 5
전체 시간: 932
