Will not power up. Does not show up when plugged into computer
Will not power up. Does not show up when plugged into computer. tried new batteries and taking them in and out a bunch of times to try and reset. no lights at all
좋은 질문 입니까?
좋은 질문 입니까?
Ephiram Bosse time to take a closer look at it. you do want to check the battery connections to make sure that the battery provides power on the connector. After that you want to check the micro USB connectors on the motherboard to make assure all of that is connected/soldered. Post some pictures of your boards so we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that and use this guide GoPro Hero3+ Black Edition Motherboard Replacement to work on your GoPro
안내서
난이도:
아주 쉬움
2 - 5 minutes
안내서
난이도:
운영
10 - 15 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 61
